Activity › Forums › DVD Authoring › Alternative to Adobe Encore in PC
  • Alternative to Adobe Encore in PC
    Posted by Paco Bech on December 10, 2012 at 5:37 pm
    Hello, I had a problem with my Imac DVD recorder and I have to use a PC to create a DVD out of M2V and waw files. I did the conversion with premiere and use Encore to make DVDs. I been triying Nero and other programs, but I cant find one to work with these files. Is there something reliable like Toast or Encore I can use in a PC?
    best regards
    David Rehm replied 13 years, 9 months ago 3 Members · 3 Replies
  • Eric Pautsch
    December 10, 2012 at 9:31 pm
    The problem isn’t the authoring tool but the files you are giving it. How are you encoding?
  • Paco Bech
    December 13, 2012 at 6:49 pm
    My PC is not 64 bits and I can Install Encore. I have the m2v and waw files created in premiere in my Imac ,
    what software can I use with a PC to create a DVD with those files, I tried Nero with no results
    best regards
  • David Rehm
    December 14, 2012 at 7:08 pm
    You can create the DVD pretty easily with Encore. Encore needs Mpeg2 files. Or if you are able to use Dynamic Link (depending which version you have – it always helps others to help you when you list the software version you are working with – it makes a big difference) and bring in the Premiere Pro sequences and let Encore do the transcoding.
    David R.
