Activity › Forums › Adobe After Effects › Alternative Radio Wave Technique ?
Christopher Rotter replied 17 years, 3 months ago 3 Members · 33 Replies
Greg Neumayer
July 1, 2009 at 8:07 pmAh, yes. That relates to the type of radio waves you’re making. If you turn on your wave type to “mask”, you can select it from your masks that are drawn on that same solid. Haven’t used it so I can’t really tell you how it’d be useful. All I can tell you is that I haven’t needed it yet.
Antifreeze Design
https://www.antifreezedesign.com -
Christopher Rotter
July 1, 2009 at 8:34 pmI have another layer in which I applied the mask to and that is working out, except the color of the layer is showing up in the mask how can I eliminate that?
Christopher Rotter
July 2, 2009 at 1:19 amI have got it figured out and done, thank you for some insight Greg 🙂
