Activity Forums Apple Final Cut Pro Legacy Alternative Codecs
  • Alternative Codecs
    Posted by Zvi4343 on April 6, 2007 at 4:28 am
    Hello All,
    I am looking to hear about successful examples of
    using various codecs other than the standard (NTSC/DV,
    DVCProHD, etc.) to edit with in FCP.
    The goal is to have footage shot around around the
    world on various formats (NTSC, PAL) to be encoded
    ASAP and FTP’d back to the home office for editing. I
    expect each “reel” of talking heads to be approx one
    hour in length.
    Manageable file size and FCP stability (no rendering)
    are of utmost importance. Quality is not secondary,
    but final output is more concerned with audio over
    picture.
    I am only interested in hearing about tried and true
    methods. Thanks in advance.
    Sincerely,
    zvi
    Devin Crane replied 19 years, 5 months ago 3 Members · 2 Replies
  • John Pale
    April 6, 2007 at 4:36 am
    [zvi4343] “Manageable file size and FCP stability (no rendering)
    are of utmost importance.”
    Only the “standard” codecs are compatible with FCP’s realtime architecture. If you use anything other than those you mentioned, you will have to render everything.
    If you want managable file size for SD, then DV25 or DV50 is probably best. For HD, then DVCPROHD.
  • Devin Crane
    April 6, 2007 at 5:41 pm
    IMX30 is a much better alternative to DV with roughly the same size just a little bigger and almost visually lossless and still 4:2:2. About the same as DV50 but it’s 720×486 not 720×480. It was developed by Sony so it should have a good transfer for PAL/NTSC. Supported by FCP 5.1. We use IMX50 and love it, can’t tell the difference between it and ucompressed 8bit but a qtr of the size.
