Activity Forums Apple Final Cut Pro Legacy Alter QT TC – Sebsky Tools vs. FCP Modify TC command
  • Alter QT TC – Sebsky Tools vs. FCP Modify TC command
    Posted by Bill Dewald on January 26, 2008 at 1:48 am
    Read this in a post below (one of Shane’s awesome stock answers)- and I have a tangential question:
    Also, if you just had a black QT file, you can change the starting TC to suite the tape; i.e. 00:58:00:00 or 02:58:00:00 etc without going back into FCP or Xpress Pro and rendering out another QT. To do this, just use Sebsky Tools to alter the starting TC of the file.
    https://www.dharmafilm.com/sebskytools/
    I’m faced with a situation where I need to create timecode tracks within a number of Quicktime files that were acquired outside of FCP. I was planning on using the Modify/Timecode… command within FCP. Is there a compelling reason to use Sebsky Tools instead?
    Thanks – Bill
    FCP 5.1.4 – QT 7.1.6 – PPC G5 – Xsan storage
    Bob Roberts replied 18 years, 6 months ago 3 Members · 2 Replies
  • Bouke Vahl
    January 26, 2008 at 11:21 am
    No difference.
    Easy of use can be your desicion.
    Both generate a fresh QT timecode track in your video.
    hth,
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Bob Roberts
    January 26, 2008 at 5:37 pm
    I’m using 10.4.11 and I can’t even get the program to run. Any suggestions?
