Activity Forums Adobe After Effects Alter motion blur amount?
  • Alter motion blur amount?
    Posted by Mark Landsburger on December 3, 2005 at 1:32 am
    Hey all,
    I was wondering if there is a way to alter the amount of motion blur you get when checking the layer? I need to tone it down, and the only other thing I could think of (add layer above it with none, and reduce opacity) doesn’t look right.
    Thanks a bunch,
    lands
    Mark Landsburger replied 20 years, 9 months ago 3 Members · 4 Replies
  • Filip Vandueren
    December 3, 2005 at 1:48 am
    I assume your talking about toning down the blur on one layer only…
    because the overall effect of motion-blur is governed by the shutter setting of a composition.
    If changing that doesn’t do it for you:
    You can add motion blur as an Effect: Time->Force Motion Blur.
    This has quality settings + it has it’s own shutter, deselect “use comp’s shutter” and use a lower value to get a less pronounced smear.
    You use it on a layer that does not have Motion-blur enabled.
  • Jon Herron
    December 3, 2005 at 1:49 am
    Go to your Composition Settings > then Click the Advanced Tab, and then change your camera shutter angle to what you desire. HIGHER the angle more blur LOWER the angle less blur.
  • Jon Herron
    December 3, 2005 at 1:51 am
    Hey Filip, is Force Motion Blur on 6.5??
  • Mark Landsburger
    December 3, 2005 at 1:55 am
    Thanks guys – I’ll alter as needed.
