Activity Forums Adobe After Effects ALT + ] or [ dont work for me
  • ALT + ] or [ dont work for me
    Posted by Samijo on December 9, 2005 at 7:15 pm
    Hallo.
    I have several times tried to shorten layer using Alt + left bracket (alt + ])
    but I cant get it work. I have no ide if its only my keybord that cant get it work or if AE has changed the keys in AE 6.5.
    I live in Sweden europe and may we have other keys than in US.
    anyway, i need help whit this simple one cause its starts too get enoing too shorten every layer by himself…
    Samijo replied 20 years, 9 months ago 3 Members · 4 Replies
  • Tim Kurkoski
    December 9, 2005 at 7:30 pm
    It probably is because the Swedish keyboard layout is different. On international keyboards, sometimes when symbols are relocated to different keys, the keyboard shortcuts remain with the the physical key, not the symbol. (I think it has to do with the fact that the signal AE looks for has less to do with the symbol being pressed and more with the actual key being pressed.)
    Here’s an interactive picture of the US keyboard layout:
    https://www.microsoft.com/globaldev/keyboards/kbdusx.htm
    And the Swedish for comparison:
    https://www.microsoft.com/globaldev/keyboards/kbdsw.htm
    I can see that the keys where the bracket symbols are in the US layout are used for something else in Swedish. What you need to do is use the same keys on the keyboard, even though they’re labeled differently. (I don’t know what those symbols are called in Swedish. If only my grandmother were still alive.)
  • Samijo
    December 10, 2005 at 1:01 pm
    Hallo thanks a lot for your answer. I tried to use the keys Us use for bracket in sweden its
  • Enzo Tedeschi
    December 10, 2005 at 11:51 pm
    This may be a silly question, but have you tried both Alt keys? (ie Alt and AltGR?). ALTGR + [ doesn’t work on my Keyboard, but Alt + [ does…
    e.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Samijo
    December 12, 2005 at 11:40 am
    Yes and it didnt work either. So what I did is that i have to change in the script — Windows: Documents and Settings/ [user name] /Application Data/Adobe/After Effects/Prefs .
    i changed frome bracket to keys 8 and 9 and now it works…I hope…;-)
    Peter
