Activity › Forums › Adobe After Effects › “alt+[” or “alt+]” not working
  • “alt+[” or “alt+]” not working
    Posted by Afshar Afshar on April 12, 2009 at 1:25 pm
    hello
    I’m having a problem with the trim shortcut. the manual says alt+] trims the out-point of a layer. but whenever I do that it simply doesn’t work. not with the left sided alt or the right sided alt.
    is this a know issue? I’ve done some google and searched the forums here and found one post where the alt+[ didn’t work but that was due to the alt button malfunctioning. here this is not the case.
    afshar
    Curious Turtle replied 17 years, 5 months ago 2 Members · 3 Replies
  • Afshar Afshar
    April 13, 2009 at 3:37 pm
    yes on both questions.
    but I found what the shortcut is I was trying different combinations
    and after a while I found that here it’s ctrl+alt+, for the out and ctrl+shift+, for the inpoint.
    strange
  • Afshar Afshar
    April 13, 2009 at 8:50 pm
    actually I’m mistaken. these shortcuts timestretch the layer to the place where the timeline cursor is.
    so the problem still remains.
  • Curious Turtle
    April 14, 2009 at 6:10 am
    If you’re working with a non-US/GB keyboard this could be the problem. On Windows I have to change my language settings to EN from Danish, then I can use Alt-å and Alt-¨ to set in and out points.
    They just happen to be the two keys to the right of the P key, so correspond to where [ and ] would be on a standard English keyboard.
    Could that be the issue?
    Cheers,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
    Just out: Rock Steady : Successful Motion Tracking in Mocha & After Effects
