Activity › Forums › Apple Final Cut Pro Legacy › Also, why do I have to render….?
  • Also, why do I have to render….?
    Posted by Kat Nofs on April 19, 2005 at 2:18 pm
    I have been working on a 23.98 timeline after using the pulldown removal, and I overwrite clips in the sequence with no problem. All of a sudden it wants me to render each clip I put in there. It wasn’t doing this before. And I made sure all the settings are where they are supposed to be.
    Thanks, K
    David Bogie replied 21 years, 5 months ago 2 Members · 1 Reply
  • David Bogie
    April 19, 2005 at 3:59 pm
    I’ve seen this happen when you suddenly reach the end of your hardware’s capacity to process and display all of the images in realtime. It’s often caused by adding just one more clip or one more filter.
    Sorry, best I can do. Only seen this once or twice on my DV projects when I’ve got like 50 jpg or psd
    files all scaling and moving, aka the Kevin’s Burned Effect.
    bogiesan
