Activity Forums Maxon Cinema 4D Also stuck in 32 Bit.
  • Also stuck in 32 Bit.
    Posted by Anthony Sipsas on February 7, 2013 at 7:58 pm
    C4D R14. OSX 10.7.5, 32GB ram, 2x 2.93 Quad Xeon
    Testing various settings in C4D to get “looks” when I was done and set back to an 8 Bit setting, I noticed that now, no matter what setting im using, C4D is taking forever to render, and its stuck in 32 bit.
    (This is confirmed by the bottom of the Render Window which states “Size (1920×1080 (32Bit))”, even though im attempting to render out 8 bit tiffs.
    Is there a setting which is over-riding this?
    Anthony Sipsas replied 13 years, 7 months ago 2 Members · 3 Replies
  • Dan Conrad
    February 8, 2013 at 1:40 am
    Are you sure you don’t have a render preset active and think you are making changes even when you are not? The “white” one is active in the render settings. My Render Setting One is set to 32bit and is yellow, which seems active, but actually My Render Setting.1 is the one that would be used for the actual render .
    @mographcandy
  • Anthony Sipsas
    February 8, 2013 at 1:48 am
    Pretty Sure. Heres what Im looking at:
    Any ideas?
  • Anthony Sipsas
    February 8, 2013 at 1:50 am
    Is that because of the alpha? Why is there such a significance in render time?
