Activity Forums Blackmagic Design Also Posted in premiere forum
  • Also Posted in premiere forum
    Posted by Ray K on July 9, 2005 at 1:20 pm
    Hi all
    when capturing from a digi beta there are 4 audio channels mixed in with the video. With the Decklink series of cards they support 8 channel. when i capture useing decklink asio drivers i get the 4 channels but there seem to be no way to separate or iso any of them.. Suppose ch1 was vo. ch2efx ch3and4 were music stereo. U have to use 5.1 capture mode but there is no pan or front to back adjustments. Any help would be great. thanks in advance
    regards
    ray
    Michael Mueller replied 21 years, 2 months ago 3 Members · 5 Replies
  • Lemmur
    July 11, 2005 at 8:16 am
    hi,
    I have the same problem (xp & prempro) and posted it here about two months ago – but no replies…guess we have to wait for new drivers. my workaround: batch-capture channel 3+4 via xlr (analog yuv-mode, audio only in prempro). how is this working with fcp 5 and the new drivers???
    cheerz, lemmur.
  • Ray K
    July 11, 2005 at 1:31 pm
    hi lemmur
    It seems like A.nobody needs four channels or B.its not possible. Have you tried setting capture mode to 5.1? this captures the 4 channels but I havent found a way to either sepperate or pan or iso or do anything with it. Hopefully someone from black magic will respond. My cards only take embedded audio.
    regards
    ray
  • Lemmur
    July 11, 2005 at 4:17 pm
    hi,
    yes I captured also in 5.1, but didn’t find a way to separate the channels. played a lot with the routing, export, etc… no solution. we have a dl extreme, so the workaround via xlr is possible. maybe you can change the channel-routing at your player..?
    nobody else need that???
    that’s really strange, because we have a lot of projects with m+e tracks or 2 language tracks. so you always have to capture all 4 audio-channels and it would be really cool when we could handle that with a bm via sdi and prempro… still hoping.
    or do we have to buy a dongle…what was it named..yes, apple 🙂
    lemmur.
  • Ray K
    July 11, 2005 at 5:01 pm
    Hey Lemmur
    Let hope its not a dongle fix…. My work around now is any jobs that require the 4 ch capture are done on my bluefish system. Only draw back for me is that sys only has 600 gig storage and its on a slower computer. BUT they released some fantastic drivers not long ago.. ie. realtime efx!!!!
    so maybe its time to move some cards between computers.. If you come up with a way to resolve this let me know please and i will do likewise.
    regards
    ray
  • Michael Mueller
    July 14, 2005 at 12:54 pm
    I got the same problem, though I need channels 2 and 3 which makes it even a bit more complicated.
    I found a workaround with Premiere but it is quite complicated.
    Apply the channel / volume filter to the 5.1. audio track. There you can eliminate those channels you don
