Activity Forums VEGAS Pro Alpha transparency quality
  • Alpha transparency quality
    Posted by Frank Stevn on November 1, 2012 at 10:34 pm
    I am trying to render a video with transparency to be used as lower third.
    I tried rendering using used HD QuickTime Animation and PNG ( 32 bpp) following John Rofrano and Steve Rhoden suggestions from this forum.
    I can’t get a quality transparency in some details. Please see the comparison of the images captured within sony vegas.
    In the image 1 the lower third is the QuickTime file inserted on top of the video. Note the gray color around the sun.
    In the image 2 the lower third is the original Vegas project file inserted on top of the video. Note the nice dissolved yellow color around the sun.
    Any suggestions on how to render in Snoy Vegas high quality video animations with transparency in order to use it as a lower third in other projects?
    Steve Rhoden replied 13 years, 10 months ago 2 Members · 3 Replies
  • Steve Rhoden
    November 2, 2012 at 12:09 am
    In order to get rid of that haze or gray color around the sun
    and having everything looking dissolved and blended, you right
    click on that lower third clip in the Project Media and go to
    Properties, then go down to Alpha Channel and change it from
    Straight to Premultiplied, if its already on Premultiplied, change
    it to Straight, then click OK, and you are done.
    Thats not something to be cleared up in the rendering process,
    its cleared up with what i mentioned above.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Frank Stevn
    November 2, 2012 at 12:33 am
    Thanks Steve, you are a genius !!!!!
  • Steve Rhoden
    November 2, 2012 at 1:05 am
    U R Welcome Frank.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
