Activity Forums Adobe Premiere Pro Alpha time!!!
  • Alpha time!!!
    Posted by Ben Hawkins on November 26, 2007 at 9:29 pm
    When I cut out a section of video and nothing is there it will create black space, but why is it rendering as black space?? I want it to render as an alpha channel. In FCP it
    Jon Barrie replied 18 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jon Barrie
    November 27, 2007 at 12:32 am
    For AVI – Follow this:
    File>Export>Movie>Settings
    General> File Type> Microsoft AVI
    Video> Compressor> None
    Color Depth> Millions+ of colors
    Or and Image Sequence
    General> File Type> Targa/TIFF/
    QT formats don’t import properly to PPro when they have alpha channels.
    If you want to use QT follow this: (will work in AE)
    General> File Type> Quicktime
    Video> Compressor> None/Animation/PlanarRGB/PNG/TGA/TIFF
    The key ingredient is the Millions+ the + is the alpha channel.
    – Jon 🙂
  • Mike Velte
    November 27, 2007 at 12:14 pm
    I cant get it to work. I dont think Premiere recognizes a blank spot as an alpha channel. I had to put a blank title in the blank space and then it worked.
  • Ben Hawkins
    November 27, 2007 at 9:32 pm
    Yeah, and the Uncompressed AVI doesn
  • Jon Barrie
    November 27, 2007 at 9:56 pm
    Either one of the processes I suggested is the way it works. They are uncompressed options as compression and alpha dont work in avi.
    How are you coming to the conclusion that it’s not working? The millions + alpha channel is based on nothing being under the layer with some of it removed.
    It is different to AE, following the steps above is how to do it, there is no preset uncompressed alpha like AE.
    – Jon
  • Mike Velte
    November 28, 2007 at 11:36 am
    I experimented by exporting a split clip with a blank space in the middle…as millions+. Put the new uncompressed clip on V2 over a background…nothing coming thru.
    Repeated the experiment with an empty title in the blank space and that does contain an alpha channel.
  • Ben Hawkins
    November 28, 2007 at 4:39 pm
    It does work.
    You are correct, But if I want to use any uncompressed mode the million + option is gone.
    But my question was answered. Thanks guys!
    Ben
  • Jon Barrie
    November 29, 2007 at 12:36 am
    Hi Mike,
    The Uncompressed setting doesn’t contain the millions+ colors so that won’t have the alpha channel embedded. Using Microsoft AVI compressor none will. It should work. I did a test and it worked fine for me.
    – Jon 🙂
