Activity Forums Adobe After Effects Alpha Problems at 2K
  • Alpha Problems at 2K
    Posted by Rachel Gorman on April 5, 2006 at 8:36 pm
    I’ve recently encountered weird problems with the way that alphas are calculated on my 2K renders. I am rendering text with a basic drop shadow / glow combination at 1828×1332 (flat) and 1828×1556 (scope) resolution as SGI sequences. This is a pretty standard thing that I’ve been doing for years.
    These SGI sequences have gone to two different post houses for film-out. I assume that the operators there are working on an Inferno or similar. What they are describing is a “chunky, black” drop that does not resemble the NTSC reference. I have not seen this myself, but both operators gave same description.
    When I pull my sequences back into AE to check them, they look perfect.
    Nothing on my system has changed that I am aware of and I am using the same render output module that I’ve been using for the past two years without problem. The last two projects I have finished for film in the course of a month have had the same problem.
    Any ideas?
    DG
    I’m using:
    Standard AE Drop Shadow + Standard AE Glow
    Mac OS X V10.4.6 AE V6.5.0.97 QT V7.0.4
    Peter O’connell replied 20 years, 5 months ago 3 Members · 3 Replies
  • Steve Roberts
    April 5, 2006 at 9:28 pm
    Hmm … and you’re sure that nothing has changed at the post houses in the last month?
    Or … can you try dropping the sequences into something other than AE? I don’t know … FCP?
  • Rachel Gorman
    April 5, 2006 at 9:40 pm
    At first I attributed it to operator error, since we were finishing at a new place. But the last one turned up the same result at the post house we usually use.
    Nothing I know of has changed on my system. We’ve even held off on the AE upgrade.
    Hmmmm …
  • Peter O’connell
    April 14, 2006 at 5:17 am
    Hi try rendering out with your alpha set to straight or possibly premultiplied with black.
    That might do the trick
    Pete
    Friday; April 14, 2006
    1:18 AM
