Activity Forums Blackmagic Design ALPHA on Blackmagic Codec?
  • ALPHA on Blackmagic Codec?
    Posted by Austin Ray on May 19, 2006 at 6:47 am
    Hi!
    Im working on som supers for a concert. Unfortunately theres a lot of them, and the Avid Media Compser is old (9000) so importing them as files is a hopeless thing to do.
    Is there any way I can make the graphics into Blackmagic codec with alpha channel? (so that it will send on SDI OUT while using Blackmagic Deck Control).
    Or is there a way to send any other codec supporting alpha on SDI OUT?
    Chris Borjis replied 20 years, 4 months ago 4 Members · 3 Replies
  • Chris Tompkins
    May 19, 2006 at 1:11 pm
    I think if you’re going out to tape u will not have an alpha channel.
    Bring in the footage – put your super on and then lay out to tape might be the way to go.
  • Chris1621
    May 19, 2006 at 1:43 pm
    Hello,
    Doesn’t the Blackmagic support real-time .tga files? Could you render your titles with alpha that way?
  • Chris Borjis
    May 19, 2006 at 3:53 pm
    I think the live key function only works on a still frame like a bug for network tv.
