Activity Forums Adobe After Effects Alpha needs to be solid and not look like RGB.
  • Alpha needs to be solid and not look like RGB.
    Posted by Justin Mettam on August 15, 2016 at 8:40 pm
    I am trying to create a sphere by blurring a circular mask then using the same mask to cut out the blur. This works well in RGB but the Alpha looks the same as the rgb. How can I make the alpha a solid white circle while keep the rgb feeling spherical.
    See attached image of my simple AE comp stack.
    Darby Edelen replied 10 years, 1 month ago 4 Members · 4 Replies
  • Walter Soyka
    August 15, 2016 at 9:18 pm
    How about a single solid layer, cut with a circular mask, consisting of a Gradient Ramp set to radial, plus Curves or Levels to tweak?
    Or an Inner Shadow layer style?
    Or a black circle below your stack there, not cut with the blurred version?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Justin Mettam
    August 16, 2016 at 4:26 am
    Thanks for responding Walter. Your ideas have given me something to work with.
    Is there a way to make a normal map (in AE) out of a photo or a grey shaded graphic? I
    Justin Mettam
    PreViz & 3D-Generalist
    mettam@hotmail.com
    415 261-7633
    http://www.JustinMettam.com
  • Kalleheikki Kannisto
    August 16, 2016 at 8:32 am
    You can also adjust alpha channel only with curves.
    Senior Graphic Designer
  • Darby Edelen
    August 23, 2016 at 8:44 pm
    [Justin Mettam] “Is there a way to make a normal map (in AE) out of a photo or a grey shaded graphic? I”
    You can kind of get close by using Emboss, Shift Channels and the Add blend mode. Unfortunately AE lacks the tools to perform normalization on the resulting color values. Perhaps there’s a 3rd party solution.
    Darby Edelen
