Activity › Forums › Apple Final Cut Pro Legacy › alpha mov by decklink codec??
Posted by Romy Marx on February 20, 2008 at 7:21 pmhi
how can i render mov file using decklink codec but including alpha channel??
is this possible using decklink codec??all the best
romyJeremy Garchow replied 18 years, 6 months ago 4 Members · 6 Replies -
Russell Lasson
February 20, 2008 at 9:19 pmI don’t think any of the decklink codecs support alpha channels. You could render the alpha out separately if you wanted to, then combine then in whatever program you’d use.
-Russ
Russell Lasson
Kaleidoscope Pictures
Provo, UT -
Ed Arsuffi
February 20, 2008 at 9:43 pmDepending upon your needs you could use the Animation or None CoDec’s. Both support embedded alpha.
Romy Marx
February 21, 2008 at 5:10 pmbut it needs to render on the timeline cuz it is not native codec of decklink which plays in realtime…??
i need any solution for real time on timeline..
romy
ROMY
Jeremy Garchow
February 22, 2008 at 2:17 amSorry, FCP does not support real time alpha channels.
Please voice your concern at the Apple Feedback page and hopefully they will enable a real time alpha channel codec.
Jeremy
Romy Marx
February 22, 2008 at 4:00 pmbut does it have operator as merge matte with video?
is it their?if yes,..is it realtime?
romy
ROMY
Jeremy Garchow
February 22, 2008 at 4:16 pmYes, you can use the ole matte and fill option as you can with any codec and then composite them. No it is not real time.
Jeremy
