Activity Forums Adobe After Effects Alpha Matte Not Working Correctly
  • Alpha Matte Not Working Correctly
    Posted by Curtis Cosby on October 10, 2014 at 1:29 pm
    I have looked through some posts but can’t find my answer. I have created a falling Polaroid composition following Evan Abrams tutorial. https://vimeo.com/66751770
    All is working as I want it to except, as the photos fall on top of each other the bottom photo shows through, which I don’t want it to.
    I am fairly new to after effects and have checked everything I can think of. See the attached photo for reference. Any help would be appreciated.
    Curtis
    Curtis Cosby
    Multimedia Assistant
    Jm Chadillon replied 11 years, 10 months ago 2 Members · 2 Replies
  • Curtis Cosby
    October 10, 2014 at 2:04 pm
    I was able to figure out what was causing the issue I was having.
    Curtis Cosby
  • Jm Chadillon
    October 10, 2014 at 6:17 pm
    this is not an alpha error. You have to make sure that you set apart your layers in Z space. It looks like what you are doing is with 3D layers. Even offsetting the Z position by 0.5 or 1 will tell after effects which layer is actually in front of the other without changing your overall animation or look too much.
