Alpha matte issues
Hello all,
I’m trying to get an Alpha Matte out of AE to use in FCP.
It needs to be DV PAL, lower field first. So I’ve set that up, then checked alpha only in the render options. I’m left with a black and white quicktime. Nice.
The problem comes when I try to set it up as an alpha matte in FCP. It’s just not recognising the alpha channel at all (no checkerboards in the background when I double click the clip – just black). So when I set it up in the timeline and change the blending mode with some video underneath as the manual suggests, nothing happens.
I’m sure I followed the exact steps a while ago with success, so I’m stumped this time – I can’t see how I can do anything differently. I’m definitely not leaving a solid or anything at the bottom of the stack in AE, and changing the alpha option to straight/black/white doesn’t work in FCP (it defaults to non/ignore).
Any thoughts??
Nico
