Activity Forums Live Events & Streaming alpha key on panasonic av-hs450 multiformat live switcher
  • alpha key on panasonic av-hs450 multiformat live switcher
    Posted by Simon Zehentner on September 16, 2010 at 5:04 pm
    hello
    until now i always worked with chroma keys for live production. but now i have to set up a key for graphics with alpha channel and i don’t really now where to beginn. so if someone could tell me with which key i can mask pictures with alpha channel in general and maybe even on a panasonic switcher in particular i would be very thankfull.
    best regards from austria.
    simon.
    Danny Nguyen replied 16 years ago 4 Members · 3 Replies
  • Walter Soyka
    September 16, 2010 at 6:48 pm
    [simon zehentner] “until now i always worked with chroma keys for live production. but now i have to set up a key for graphics with alpha channel and i don’t really now where to beginn. so if someone could tell me with which key i can mask pictures with alpha channel in general and maybe even on a panasonic switcher in particular i would be very thankfull.”
    You can self-key based on luminance (this is called a luma key) just as you do with chroma-keying. This is usually used to knock a graphic off a pure black background, but has a very limited range of transparency.
    If you have separate key and fill sources, you can use a linear key. This uses the luminance of the key source to control the transparency of the fill source. Areas of the fill where the key is white are kept; areas of the fill where the key is black are eliminated; shades of gray in between allow partial transparency.
    Walter Soyka
  • Chuck Pullen
    September 20, 2010 at 7:03 pm
    I’ve just started working with a Blackmagic Decklink card with key/fill output. It eats up two very valuable inputs on the HS450A, but it does the job very well.
  • Danny Nguyen
    September 24, 2010 at 6:54 am
    hi Chuck !
    i new to av-hs450n and new to all the lowerthird graphic for live. can you hep me on setting up ? i doing a live show really soon. i dont know how to set up external key t the hs450n as dsk. if i use the internal key on the hs450n the graphic easily get hole in it
