Activity Forums Boris FX Particle Illusion alpha issues PI AE
  • alpha issues PI AE
    Posted by Peppe Tannemyr on May 1, 2013 at 6:49 pm
    I did just return back to standalone version VERY since alpha seems to be tricky in AE with PI AE.
    If I do a canvas 5400 x 1080 and add a adjustment layer, in full preview mode it directly goes white background, in half res preview, I have alpha….hmmm. Render out this will result in second frame in alpha, the first and rest is white background, random flickers of background
    Is this a glitch in my powerbook that have a NVIDIA GeForce 9400M , at least it should render out it with alpha all frames, but it seems that
    my version on macpro is better ( card NVIDIA GeForce GTX 285), but makes first frame white, and random frames white…..
    1920 x 1080 seems just to render out the first frame white
    Any hints here ?
    Peppe Tannemyr replied 13 years, 4 months ago 2 Members · 3 Replies
  • Peppe Tannemyr
    May 1, 2013 at 8:08 pm
    Tested to render out some part when I have purged all kind of memory AE would have made up.
    in AE5.5 it works better but often ends up in really distorted artifects on the clip, f.ex parts of the emitter on various places, and lines streched out etc.
    Purge seem to make some parts better, but some openGL issue are seen in PI AE
    All this is not seen in standalone.
    AE6 seems to ignore that it´s with alpha big time….
    I do hope it is some solutions, and a upcoming version since the idea is great to have in AE.
  • Alan Lorence
    May 2, 2013 at 6:04 pm
    Please email support at genarts dot com with this information if you haven’t already. Please provide as much information as possible, including screenshots or a couple of rendered files.
    One thing you can do to see if it’s memory-related is to set a region of interest, and see if the alpha starts behaving.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Peppe Tannemyr
    May 2, 2013 at 7:23 pm
    Ok, I do that!
    Maybe it come to a solution, that would be great!
