Activity Forums Adobe After Effects Alpha – inserting new footage behind presenter
  • Alpha – inserting new footage behind presenter
    Posted by Chris Pulleyn on September 20, 2009 at 11:32 pm
    Hi All
    I have recieved a .mov, of a presenter moving and talking, green-keyed. He is now on white apparently with an alpha including him and his shadow.
    My question is; how do get the presenter’s layer to support passing other footage behind him. I have tried various layer mode changes and obvious Alpha commades but keep loosing his density/transparency or luminosity. If I re-key the white I loose most of him and his shirt!
    Using: AE-CS3 on pc. Editing with Edius Pro 4
    I have looked all over and everyone explains keying but not alpha manipulation
    Chris Pulleyn replied 16 years, 11 months ago 2 Members · 2 Replies
  • Laurie Turner
    September 21, 2009 at 1:19 pm
    I am a little confused. Are you saying you have him keyed but with a white background in one .mov file? You don’t have him on a seperate layer and the white background on the another layer? If that’s the case then all you can really do is roto scope him out. You can try to create a matte like andrew kramer’s sky replacement video on videocopilot.net
  • Chris Pulleyn
    September 21, 2009 at 3:14 pm
    Thanks Dave & Laurie,
    I have done alot more reading since the post and came to the conclusion i was in trouble.
    I didn’t want to go back to the producer with a silly question like “did that footage NOT have an Alpha?” but I got an updated version this morning and this one worked straight away…. so it seems that it wasn’t there.
    BTW Can I fine tune the Alpha though or is it WYSIWYG?
    There is still a bit of a white shimmer around him.
    It is a low level web-edit but as I’m at it I’d like to get it as right as i can.
