Activity Forums Maxon Cinema 4D Alpha cut-out
  • Alpha cut-out
    Posted by Mark Madsen on January 3, 2018 at 7:47 pm
    Hi all. I’m having a problem with a label on a bottle. I created the bottle and made a cylinder just larger in circumference for the label. The cylinder has a narrow break in it. I added a png to a material and applied it to the label. To round the edges, I added alpha and transparency and have tried a combination of both. No matter what I try, the edges of the cylinder are visible outside of the rounded corners of the png. Anyone have any suggestions?
    Adam Trachtenberg replied 8 years, 8 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    January 3, 2018 at 9:23 pm
    Can you upload the texture?
  • Mark Madsen
    January 3, 2018 at 10:24 pm
    Actually I got a reply from another forum. I hadn’t checked Evaluate Transparency in the render settings.
  • Adam Trachtenberg
    January 4, 2018 at 3:19 pm
    Thanks for following up.
