Activity Forums Adobe After Effects Alpha Channel/Transparency on export or render
  • Alpha Channel/Transparency on export or render
    Posted by James Mason on May 13, 2008 at 5:16 pm
    Hi All
    i just started using CS3 After Effects, coming over from Sony Vegas 8 pro. i imported a video (AVI/uncompressed) into AE in which the Alpha channel is set by Vegas. i add my effect, advanced lightning, and render it out hoping the transparency is still there. But when i pull the video into Vegas, AE appears not to have generated an Alpha channel. i am using default settings of AVI export and “Make a Movie” on the composition menu.
    Can some one help me with the settings for Alhpa channel/transparency on render or export?
    the Composition consists of, imported AVI that has transparency, advance lightning layer (adjustment layers), 4 effect layers (adjustment layers) , what am i missing?
    thanks in advance
    James Mason replied 18 years, 3 months ago 3 Members · 4 Replies
  • Simon Bonner
    May 13, 2008 at 7:06 pm
    In the render queue, click on the downwards facing arrow button between where it says lossless and output module. Select from the menu Lossless with alpha. Then render as usual. AE recognises the rendered video’s alpha channel; I’m not sure about Vegas as I don’t use it.
    Simon Bonner
    youtube.com/simonsaysFX
  • Darby Edelen
    May 13, 2008 at 9:21 pm
    I would also suggest making sure that there is alpha to render in your composition by pressing opt-4 (or alt-4 on a PC) to view the alpha channel. Some effects have settings that need to be tweaked to generate the alpha properly.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • James Mason
    May 14, 2008 at 1:05 pm
    thanks Simon, i watch your videos on youtube, i really appreciate the time you take to do them. i did find it right after posting, should have known it was in the render tab some where! thanks again
  • James Mason
    May 14, 2008 at 1:07 pm
    thanks Darby, thats a great tip! i did find the rgb+alpha right after postintg this, i know i exported from sony Vegas with the Alpha channel and every thing is now working fine! thanks for your response!
