Activity Forums Adobe After Effects Alpha channels using the DV PAL codec
  • Alpha channels using the DV PAL codec
    Posted by Stu Pond on April 27, 2006 at 4:29 pm
    A client has asked for some graphics to be rendered out using the DV PAL codec for comping in FCP later on. However, when I output the movie it won’t let me specify an alpha channel, plus the render looks a little ropey compared to Animation codec, which renders crisply with the alpa intact.
    Anyone supply their graphic files in DV PAL codec with alphas? Can you make them look any good? Am I using the right codec for 16:9 DV anyway?
    Stu Pond replied 20 years, 3 months ago 2 Members · 2 Replies
  • Thomas Leong
    April 27, 2006 at 5:16 pm
    The specs for DV do not have any alpha in it. You should use QT’s Animation or Uncompressed RGBA.
  • Stu Pond
    April 27, 2006 at 5:34 pm
    I wondered if that was the case – thanks for the help!
    stigWeard
