Activity Forums Apple Final Cut Pro Legacy alpha channels in ProRes?
  • Chris Poisson
    June 5, 2007 at 12:28 am
    On export it does not seem to give that option.
  • Russell Lasson
    June 5, 2007 at 1:27 am
    From a creative cow article I read, it doesn’t.
    (which could be a good thing because the codec isn’t free or supported on windows which makes it a bad choice for distributing to graphics/effects people. But even then, I wouldn’t mind having the option).
    -Russ
  • Rafael Amador
    June 5, 2007 at 8:44 am
    I’f you got FCS2 (I haven’t yet) you can check it by your self. Just try to export a clip from FCs time line and see if you get the “Millions+” option. If is not there ther is not Alpha channel.
    Cheers,
    rafael
