Activity Forums Boris FX alpha channels in Boris Red
  • alpha channels in Boris Red
    Posted by Lilah_rose on May 11, 2005 at 4:40 pm
    I am new to Boris Red and I am having trouble rendering out an alpha channel to be used in Avid Media Composer Adrenaline. I am using the Red Engine (standalone) so that I can render out a movie file to import and manipulate in MCA without having to re-render everytime I change something. The problem is, when I render out a movie from Red and import it into MCA, I can’t get the alpha channel to work. I have tried all of the render setting options for alpha channels within Red and I have tried all the different import settings in MCA. Any ideas what is wrong?
    lilah
    Lilah_rose replied 21 years, 3 months ago 3 Members · 3 Replies
  • Stephen L. noe
    May 12, 2005 at 1:36 am
    did you export to MOV using the anamiation compression and the millions + color space? the + is the alpha channel, if it isn’t selected there is no alpha channel. Also, make sure there literally is a transparent backgroud by closing the ‘eye’ on any underlying track. I usually select the checkerboard for transparency to make sure there is a transparent background before I ever start. These settings always work for my premiere station. For my Liquid edition editing suite I use the TGA seqence which will work no matter what (in any NLE i’ve ever used).
    Good luck…
  • Steve Pankow
    May 12, 2005 at 3:59 pm
    Ditto on the previous post. When you see checkerboard, that’s the area the Avid will key through. Make sure you select “Invert Existing” on MC when importing your movie.
  • Lilah_rose
    May 18, 2005 at 3:58 pm
    Thanks for all the input. I was using Boris as a standalone, not within MCA. But once I opened the effect in MCA and “exported” (vs. render) as a targa sequence, it worked just fine. Now I’m having a different problem, though, so I will make a new post so it actually gets read 🙂
    lilah
