Activity Forums Apple Motion Alpha channels and write-on text
  • Alpha channels and write-on text
    Posted by Rich Franklin on October 4, 2011 at 12:12 pm
    I have a write-on behaviour on a shape (with Image Mask applied) that reveals some text underneath that is actually a TIFF file with transparency. I want to know if I could actually use the ALPHA channel within the TIFF file to convert to either the shape that draws the text, or as the image mas. This will then give me an accurate outline of the script font.
    My other issue is that I want the shadow to draw at the same time. The normal shadow is switched on but it is not visible in the animation. With Drop Shadow turned on, the rough outline of the shape reveals it but it is the shadow from the text, not the shadow from the light in the scene.
    Thanks.
    Jeff Greenberg replied 14 years, 11 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    October 5, 2011 at 11:57 am
    Write on – use an Image Mask – the shape that draws the text goes in there.
    The shadow? you may have to build it as a separate element with the identical image mask, or build a 3d lighting system.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
