Activity Forums Apple Final Cut Pro Legacy Alpha Channels and Final Cut
  • Alpha Channels and Final Cut
    Posted by Dan Oster on August 10, 2009 at 10:14 am
    Hey, guys. I’m trying to export some effects out of After Effects as an alpha channel for my editor who is using Final Cut Pro. The problem is that the Quicktime with the alpha channel shows up strangely in the FCP project. There are weird black borders around anything with feathering.
    Conversely, this alpha channel works exactly as it should when loaded into Premiere Pro.
    So my questions is why isn’t Final Cut reading the alpha channel properly? Is there a setting we should be using? Thanks!
    – Dan
    Dan Oster replied 17 years, 1 month ago 3 Members · 3 Replies
  • Tom Wolsky
    August 10, 2009 at 10:20 am
    Set the alpha in FCP to premultiplied with black.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Aaron Neitz
    August 11, 2009 at 12:56 am
    to make tom’s suggestion more specific: highlight the clip, go to Modify -> Alpha Type -> black
    FCP assumes unpremultiplied.
    Which, frankly, is annoying. Most CG and graphics are premultiplied.
  • Dan Oster
    August 12, 2009 at 4:03 am
    Thanks for the tips, guys. Modifying the alpha type helped, but it didn’t seem to 100% eliminate the black.
    Based on your advice, I’m rendering out the alpha channels out from AE as “straight.” That may be the solution.
    Thanks again!
    – Dan
