Activity › Forums › Adobe After Effects › Alpha Channels
  • Alpha Channels
    Posted by Martin Sterling on September 15, 2006 at 3:20 am
    how do I create an alpha channel for a graphic that doesnt have one. I was recently given a quicktime from a client of a graphic but it was simply on black. No Alpha. How do I create 1. THANK YOU IN ADVANCE
    G5 Dual 2.0 GHz processor, OSX.3.9
    Justin Productions replied 20 years ago 5 Members · 4 Replies
  • Steve Roberts
    September 15, 2006 at 4:34 am
    Key out the black with color keyer? Try another keyer if it looks bad.
  • Filip Vandueren
    September 15, 2006 at 1:00 pm
    I usually go for ‘extract’ instead of the color-keyer.
  • John Cuevas
    September 15, 2006 at 1:23 pm
    Try this
    https://www.redgiantsoftware.com/unmult.html
    Basically knoll created a quick keyer for it’s lens flares, keys out black. Free handy little plugin.
    Apply that, then apply a levels effect and change the pulldown from RGB to Alpha, then tweak your levels as needed. Generally just crush the blacks say to video imput 16 to 35.
    Should give you a decent alpha.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Justin Productions
    September 15, 2006 at 1:25 pm
    Or Transfer Mode > Screen on a pure green layer, then precomposing it, and keying it.
    It isn’t the best option… but it could come handy if keying doesn’t work.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
