Activity Forums VEGAS Pro Alpha channel/elevator results – comments, critiques?
  • Alpha channel/elevator results – comments, critiques?
    Posted by Rob Weidenfeld on July 31, 2005 at 7:34 pm
    Gary, your advice did the trick, thank you! I have posted a couple of low-res comps of the results, and was quite happy with the way it came out. Would love some feedback from anyone who would care to give it.
    https://www.visionstudios.biz/elevator.html
    Once the elevator doors are gone, and the image of the panel is static, it will switch to the same image in DVDA, which will be the DVD’s menu.
    Thanks as always…
    Rob
    Rob Weidenfeld replied 21 years, 1 month ago 3 Members · 4 Replies
  • Strobealific
    August 1, 2005 at 7:13 am
    Nice effect. I’m sure that some of us Veggie-heads would love the Veg file and PNGs.
    Marc Bowyer
    StrobeAlific Media
  • Adam Rose esq.
    August 1, 2005 at 11:00 am
    very smooth
    good stuff 🙂
  • Rob Weidenfeld
    August 2, 2005 at 4:25 am
    Thanks, Marc… I can make the PNG/VEG files available. Check on that same page in a day or two and I will put them in a ZIP file.
    Thanks for the comments.
    Rob
  • Rob Weidenfeld
    August 2, 2005 at 4:26 am
    [Fuddam] “very smooth
    good stuff :)”
    Thanks! I appreciate you checking it out.
