Activity Forums Maxon Cinema 4D alpha channel?
  • alpha channel?
    Posted by Ailsa on June 14, 2005 at 7:02 pm
    does any one know how to export a moving object from cinema 4d in an alpha chanel so its possivle to impotr it into some otyer program like avid??
    bin lookin for a whiel and cant figure it out,
    cheers,
    Ailsa replied 21 years, 3 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    June 14, 2005 at 7:26 pm
    Give the object a compositing tag and enable an object ID in the tag. Then add the object ID to your multipass render.
  • Chris Smith
    June 15, 2005 at 4:56 am
    Adam, when I do an object ID pass and marry that with the original RGB image, I get a double anti-aliasing (because the Object ID is AA’s and the RGB image is as well) so I get black fringing in the comp.
    I’ve been doing the RGB renders as straight alpha then overiding the alpha in AE with the Object ID. Is this the standard way or is there an easier solution?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Ailsa
    June 15, 2005 at 7:24 am
    is there anychance you could be more specific – apologies i ve a lot to learn in cinema 4d.
    so how do what u said to do??
    thanks
