Activity Forums Adobe After Effects Alpha channel with a lens flare?
  • Alpha channel with a lens flare?
    Posted by David Taylor on December 12, 2005 at 9:15 pm
    I’d like to make an animated logo transition for a program being edited in FCP. I’d like to use a lens flare effect across the frame as the logo rotates. In the past I’d just create a black solid and lay the lens flare on it and change it to screen to get rid of the black. That works great for most things, but I don’t get a keyable alpha channel. How can I lay on a lens flare with an alpha channel?
    David Taylor replied 20 years, 8 months ago 3 Members · 3 Replies
  • Mylenium
    December 12, 2005 at 9:22 pm
  • Serg Merci
    December 14, 2005 at 1:27 pm
    Yep,
    as Mylenium has suggested, download the UNMULT plugin for free from the website and that should fix your problem.
    I had the same problem and it fixed it with that plugin. 🙂
    Serg – Australia.
  • David Taylor
    December 14, 2005 at 3:02 pm
    Thanks, that did the trick! Haven’t had a chance to try it, but was wondering if this plugin would work with similar problems I encountered with the render lightning effect.
