Activity › Forums › Maxon Cinema 4D › Alpha channel weird stuff
  • Alpha channel weird stuff
    Posted by Todd Vanslyck on July 19, 2013 at 3:31 pm
    I’ve searched here and the general internet to figure out what the heck is going on here.
    It’s pretty straightforward, I’ve got a document with social media icons that i’m placing in a cinema scene. Background needs to be transparent.
    I knock out the background in photoshop so it’s transparent. I’ve even gone as far as creating a separate alpha channel. I create a plane in C4d the same size as my doc, create new material and import the picture into both the color channel and transparency channel, then apply the material to the plane
    Everything seems hunky dory until i render it out and some of the stuff that should be transparent (shadows and part of the background) are white.
    I’ve done psd and tga with alpha but no luck. It’s driving me flipping crazy and I can’t find a solution anywhere!
    Dell T76000 Dual 8-core 2.4 GHz
    NVIDIA Quadro 2000
    NVIDIA Tesla c2075
    Adobe Premiere Pro CS6
    After Effects CS6
    Cinema 4d r12
    Ashish Gupta replied 13 years, 2 months ago 3 Members · 5 Replies
  • Adam Trachtenberg
    July 19, 2013 at 4:08 pm
    You should use the material’s alpha channel instead of transparency. It’s possible that you’re getting a specular reflection on the transparent part.
  • Todd Vanslyck
    July 19, 2013 at 4:19 pm
    No go. Just tried it and got the same results
    NVIDIA Quadro 2000
    NVIDIA Tesla c2075
    After Effects CS6
    Cinema 4d r12
  • Todd Vanslyck
    July 19, 2013 at 4:24 pm
    Actually I take that back. the transparencies on the logo are fine, it’s only the bottom “shadow” that are still white now. I guess I’ll just chop them in photoshop. weird.
    NVIDIA Quadro 2000
    NVIDIA Tesla c2075
    After Effects CS6
    Cinema 4d r12
  • Todd Vanslyck
    July 19, 2013 at 5:19 pm
    I added my own shadow in photoshop and it does it even then. Why does it automatically add white behind anything with transparency? Is there some weird button I’m not pushing in C4d?
    NVIDIA Quadro 2000
    NVIDIA Tesla c2075
    After Effects CS6
    Cinema 4d r12
  • Ashish Gupta
    July 22, 2013 at 2:17 pm
    Todd,
    Try turning alpha channel on in cinema render settings ..
    Render settings-> save-> alpha channel
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
