Activity Forums Avid Media Composer Alpha Channel Trouble
  • Alpha Channel Trouble
    Posted by Ryan Zernec on October 29, 2008 at 6:55 pm
    Hey guys,
    We have Avid Xpress Pro where I work, and for some reason I’m having a lot of trouble importing files that have alpha channel info, like pre-made lower thirds, etc. This stuff imports fine in Final Cut, but for some reason in Avid the black areas aren’t keying out. When I import the clips is DOES say that it’s creating Alpha Channel info… but then it doesn’t work right on my timeline (and yes, I’m rendering). I’ve been through every setting I can think of. Can anyone help?
    -Z
    Andy Crow replied 17 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mark
    October 29, 2008 at 7:07 pm
    In the import settings you have to make sure that you set the alpha to invert alpha….Avid works differently than other systems, in that white is tranparent and black is opaque….other systems use the white for opaque and black for transparency.
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Ryan Zernec
    October 30, 2008 at 3:23 pm
    Thanks, I just tried this, and now I don’t get anything at all. I drag the clip down onto my timeline and nothing shows up in my viewer. If I delete the alpha my clip shows up, but again, the black isn’t keyed out. Please help!
  • Mark
    October 30, 2008 at 8:28 pm
    It sounds to me like your alpha is not right…bring the clip into After Effects, if you have it, and check out the alpha….my bet is that the alpha is a full screen….when you are reversing it, it is normal that everything dissapears.
    Mark
    Mark Harvey
    Senior Editor
  • Ryan Zernec
    November 3, 2008 at 4:20 pm
    That sounds about right. Is there any way to fix this without going into After Effects every time?
    Thanks guys!
  • Ryan Zernec
    November 4, 2008 at 10:16 pm
    All I’m trying to do is import some pre-made lower third clips from an Editor’s Toolkit set. Has anyone done this on Avid and gotten it to work properly?
  • Dave Rumbelow
    November 4, 2008 at 10:24 pm
    what sort of files are you making?
    quite a few avid qt codecs don’t carry alpha
    I find png sequences set to millions of colours+ on export from after effects work best
  • Andy Crow
    November 5, 2008 at 10:44 pm
    You may need to make sure that you have “Render on-the-fly” turned on. This is under the “special” pull-down menu at the top of the frame. That and remembering to reverse alphas on import are usually the 1st two gotchas.
    ac
