Activity › Forums › Boris FX Particle Illusion › Alpha Channel Transparency Issue
  • Alpha Channel Transparency Issue
    Posted by Jorge Salazar on August 26, 2010 at 12:13 pm
    I am trying to create a seamless particle loop and export out a png sequence so I can drop into flash. After reading the tutorial you recently gave, I am able to
    succesfully do that. If I view the avi file it works fine, but when I export out a png sequence with the “Save Alpha” checked, I notice that the first 5 or 6 images have no bitmap
    data in them (the images are just black), same goes for the last few frames. If I don’t check “Save alpha”, it works fine.
    I was wondering if this is a known issue. I was using version 3, I recently upgraded to 3.0.4.1. I am on Windows 7 64 bit.
    Jorge Salazar replied 16 years, 1 month ago 2 Members · 2 Replies
  • Alan Lorence
    August 27, 2010 at 2:16 pm
    I need you to provide me with some simple steps to reproduce this. I know that “save alpha” sounds like it’s the key, but is it because it’s 2 layers? Because it has footage on another layer?
    I need the simplest project or steps that can reproduce the problem please.
    Alan.
    http://www.wondertouch.com
  • Jorge Salazar
    August 28, 2010 at 12:14 am
    1st step: create a 60 frame particle animation, fade in the animation the first ten frames and fade out the last ten frames
    so the first and last frames are completely blank
    2. export out the 60 frame animation into a png sequence
    3. create a new layer: import in the png sequence, places frames 1-30 on project frame 31
    4 create another layer import in the png sequence places frames 31-60 on project frame 1
    this will create a seamless particle loop, if you export to avi, it works fine, it you export to a png sequence
    with “Save Alpha” unchecked, it works fine, however if I check “Save Alpha” and export out the images to be
    transparent, the first 6 or 7 frames and last 6 or 7 frames have no bitmap data or the content in them is so transparent,
    it gives the appearance that animation is fading near the beginning and end and kills the seamless loop
    I hope this makes sense, I can send the project if needed.
