alpha channel problems with red 5.04 and adobe ppro 5.5
Posted by Rob Ramselaar on July 31, 2011 at 7:50 amwhen I use two video tracks in ppro5.5 and place a red 5 transition on one of the tracks I dont see the video track underneath the transition. The same happens with a title preset.
Karel Guzman replied 14 years, 10 months ago 3 Members · 6 Replies -
Peter Mcauley
August 1, 2011 at 1:18 pmHi Rob,
Do you see both video tracks when you enter the RED custom UI? Or perhaps to rephrase this, are you seeing the same thing or a different thing when viewing the result in the Premiere Pro UI and the RED 5 UI?
Cheers,
Peter.
Rob Ramselaar
August 1, 2011 at 2:28 pmHi Peter,when I place a transition on the ppro 5.5 timeline and click on custom in the effect window the red interface is there. I see in the preset window of red the animated V1 and V2. Sofar so good. I choose myself a transition or text animation and preview the transition in red there is only the black back ground.That only happens when I put a transition using video 1 and video 2 in ppro5.5. When I put a transition on just video 1 in ppro 5.5 between two clips on the same timeline then it works oké. the transition shows the end of clip a and the beginning of clip b as it should be.
As I wrote earlier I checked the alphachannel from both facetracks but nothing helped.I read the manual and there was a chapter in the guick start that I should ctr click on the transition and could then choose alphachannel. But as far as I know was that only in the early versions of premiere. I have by the way other screenshots.I forgot to tell that I was using red,had placed a transition and then rendered all the other presets. So now you see all the presets animated with a picture of the timline I used at that moment and a black background.
With kind regards Rob -
Peter Mcauley
August 1, 2011 at 5:59 pmHi Rob,
I don’t have a quick or ready answer for this but what I would like you to do is to send me your phone number and a good time to call you and I’ll have one of our tech support gurus give you a quick call to step through this with you. It might be something simple that they would catch while going through building the effect with you. If this is okay, please send your number to me at peterm@borisfx.com. Or, if you prefer, just send them an email directly at support@borisfx.com or call them directly at 888 772 6747.
Cheers,
Peter.
Peter Mcauley
October 10, 2011 at 1:51 pmHi,
I seem to recall that there was a problem with the RED 5 Transition effect in Premiere Pro 5.5, and it’s unclear to me whether or not this problem was on our end or if the problem was something that we could have resolved. You should make sure that you have the latest version of both Boris RED 5 and also Premiere Pro – if you do not then this is the first thing to do in order to attempt to resolve the issue.
Having said that, if you use the RED 5 Filter effect you should be able to achieve the same effect as you would have with the RED 5 Transition and I’m pretty sure that this worked without a hitch.
Cheers,
Peter.
Rob Ramselaar
October 10, 2011 at 7:37 pmHi peter,the problem is solved but my problem is not solved. I want to use a boris transition,with alpha channel,in videotrack two so that I can see videotrack one halfway the transition.But You made me understand that isn’t possible exept when I use two clips on the same videotrack.
with kind regards Rob
Karel Guzman
October 16, 2011 at 12:15 pmHello folks,
I have the very same issue, I’ve even created a transparent video to see if it works adding boris effects to the video track nº2, on premiere cs5.5,(with alpha channel process) but… no luck!!!
