Activity Forums Boris FX Alpha channel problem with PSD file Boris FX/Vegas 8
  • Alpha channel problem with PSD file Boris FX/Vegas 8
    Posted by Bob Mark on February 14, 2009 at 10:04 pm
    I am trying to add Boris FX to a PSD title with alpha channel and Boris is not seeing the alpha.
    The PSD alpha works fine on the timeline, but not when I add Boris FX to it. I have the alpha on in “preferences” within Boris.
    Is there another alpha setting that needs to be toggled on? Thanks.
    Bob Mark replied 17 years, 6 months ago 3 Members · 3 Replies
  • Mukesh Shah
    February 17, 2009 at 9:00 pm
    Hi Bob,
    Alpha is not passed to Boris UI when applied as a Filter. You will need to bring the alpha file straight into FX UI. So,
    1) apply FX as a Filter to a video clip & then launch Boris FX UI & layer on V2 the alpha file by bringing it straight in Boris FX UI etc
    or
    2) apply Boris FX as a Filter in Vegas to an Empty Event on V2 & then launch Boris FX UI & bring in the file with alpha in FX UI etc
    or
    3) apply Boris FX FX as a Generator (instead of applying it as a Filter to an Empty Event on V2) on V2 in Vegas & then launch
    Boris FX UI & bring in the alpha file straight in there etc
    note: this is a Static Generator with 1 frame duration so you won’t be able to animate. If you want to animate then you need to follow steps in 1 or 2.
    Hope this helps.
    – Mukesh Shah
    Boris FX, Inc.
  • Peter Mcauley
    February 17, 2009 at 9:16 pm
    Vegas will not pass us alpha when applied as a Filter. You will need to bring the alpha file straight into FX UI. So,
    1) apply FX as a Filter to a video clip and then launch us and layer on V2 the alpha file by bringing it straight in FX UI etc
    or
    2) apply FX as a Filter in Vegas to an Empty Event on V2 and then launch us and bring in the file with alpha in FX UI etc
    or
    3) apply FX as a Generator (instead of applying it as a Filter to an Empty Event on V2) on V2 in Vegas and then launch FX UI and bring in the alpha file straight in there etc
    Cheers,
    Peter.
  • Bob Mark
    February 17, 2009 at 9:41 pm
    Thank you. I kind of figured that maybe that was the case.
    Thanks.
    Bob
