Activity › Forums › Maxon Cinema 4D › Alpha Channel Problem
  • Brian Jones
    February 28, 2013 at 10:08 pm
    I’ll upload another test in a bit
  • Brian Jones
    March 1, 2013 at 1:34 am
    more proximal stuff (because it can control the shape) – 5552_waketrial.c4d.zip
  • Juan Carreras
    March 1, 2013 at 4:59 pm
    Thanks again Brian.
    I managed to taper the coordinates by applying a taper in ‘within box’ mode behind the ship to the extents of the proximal plane you added. Then I used ‘generate coordinates’ to convert the flat coordinates to UV so now the taper actually deforms the map along with the mesh. Then I added a parent constraint to the taper to be dragged along with the ship. Done.
    Thanks for all your tips and tests.
Page 2 of 2
