Activity Forums Maxon Cinema 4D Alpha Channel Problem
  • Alpha Channel Problem
    Posted by Dave Edwards on August 15, 2010 at 10:52 am
    I can’t seem to get the Alpha channel working properly when importing to Sony Vegas. I have a very simple scene with no background.
    It did work once but since has either not worked or else only the last frame of the clip was correct.
    I have a couple of objects which are lit and a target camera is following a spline,- that’s it. There is no background.
    I’d be very grateful for any help with the proper settings for this.
    Dave Edwards replied 16 years, 1 month ago 2 Members · 3 Replies
  • Oliver Clarke
    August 15, 2010 at 12:12 pm
    Im not sure about vegas, but After Effects doesnt seem to ever recognise my alpha channels from C4D. Unless i use .RLA format, which i take it Vegas wont handle. I have resorted to importing both the beauty pass and alpha as separate layers and making the alpha into a luma key matte. Again I dont know is this is possible in Vegas. but its certainly worth a try.
  • Dave Edwards
    August 15, 2010 at 1:46 pm
    Incidentally, I can see the Alpha channel pictures as a series of .TIFF stills in my target folder.
  • Dave Edwards
    August 15, 2010 at 5:11 pm
    Thanks, Oliver. I managed to make the thing work,- I’m not entirely sure how, – and took screenshots of all the settings!
