Activity Forums Adobe After Effects alpha channel probelms with tgas
  • alpha channel probelms with tgas
    Posted by Ian_mac on March 28, 2006 at 1:21 pm
    Please help me!!!
    Every time i render a targa sequence with a straight built in alpha (with a black backgnd in the composition), the rendered targa stills have a dfferent coloured alpha backgnd.
    Why is this happening?
    Is it a bug?
    Can i resolve it?
    Help!!!!!!
    ian
    Christopher R. green replied 20 years, 5 months ago 3 Members · 4 Replies
  • Steve Roberts
    March 28, 2006 at 2:16 pm
    If you have rendered with “straight alpha” to a format that supports millions+ colours, then your backgrounds should be transparent.
    In which application do you see these different coloured backgrounds in the imported rendered TGAs?
  • Ian_mac
    March 28, 2006 at 2:36 pm
    only when i open them in the preview application.
    They are fine in photoshop.
    I’m just concerned because i then have to import it into Clarity to go to transmission and was told i had to render with a black backgnd.
    I too thought i would not matter if it was a straight alpha.
  • Steve Roberts
    March 28, 2006 at 3:30 pm
    I’d guess that the Preview app doesn’t know what to do with alpha channels.
    Have you sent a test to the Clarity? If I were unsure, that’s what I’d do.
  • Christopher R. green
    March 29, 2006 at 2:50 am
    Make sure you have 32bit selected in the targa options dialog when you render in ae.
    … maybe this is the issue ?
