Activity Forums Adobe After Effects Alpha Channel on Export Not Showing
  • Alpha Channel on Export Not Showing
    Posted by Craig Bass on June 25, 2009 at 9:03 pm
    I am attempting to export a lower third that I created within After Effects for use within Final Cut. The Composition does have an alpha channel, and I have set the render output to lossless with alpha; however, when I import the resultant .mov into Final Cut the background is a solid black. What is going on here? Why am I not ending up with an alpha?
    *Craig*
    David Bogie replied 17 years, 2 months ago 3 Members · 2 Replies
  • Kevin Camp
    June 25, 2009 at 9:32 pm
    also, there should be some way of checking the footage interpretation in fcp, it may be that fcp is set to ignore the alpha for that footage.
    to verify that the footage does indeed have an alpha channel, bring it back into ae, then you’ll know whether it was rendered correctly from ae, or if it is a problem seeing the alpha in fcp.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • David Bogie
    June 26, 2009 at 3:57 pm
    [Kevin Camp] “to verify that the footage does indeed have an alpha channel”
    You can do the same in FCP, set the viewer or canvas to show alpha.
    bogiesan
