Alpha Channel Not Showing Up
I have a shot which is 32 seconds long. At about the 31 second mark there’s an animation which uses the alpha channel. I’ve been rendering with the Animation codec, which supports alpha channel, and selecting the ‘RGB & Alpha’ option, but the alpha won’t show up. When I lay the shot over the video in FCP, the alpha portion is black. Only when I render a portion of the shot, about the last 4 seconds, does the alpha channel show up, and I have to add that as a tag at the end of the FCP shot to get the desired effect. But why won’t it render the alpha channel when I render the entire 32 second shot? Any ideas?
