Activity › Forums › Avid Media Composer › Alpha Channel not showing up
  • Alpha Channel not showing up
    Posted by Wilmot Media on January 28, 2008 at 4:07 pm
    I’m having an issue with an alpha channel showing up in Avid Xpress pro. Its a QT movie made in Boris Red rendered with the animation codec + alpha. When I bring it into avid there’s no alpha channel. This was as an MXF format. When I switched my import settings to OMF, it worked. I’m assuming that MXF does not read the animation compressor correctly. If this is true, is there a codec that I should use when importing to this Avid?
    Brian Thomas replied 18 years, 8 months ago 2 Members · 1 Reply
  • Brian Thomas
    January 29, 2008 at 3:55 pm
    I don’t know the answer, but you should post this in the Boris forums
    Avid Editor
    New York City
