Activity Forums Maxon Cinema 4D Alpha channel icicles
  • Alpha channel icicles
    Posted by Jack Cook on November 22, 2005 at 3:05 pm
    I have a relief object in which I’ve used a greyscale height map that doesnt’ fill up the rectangle of the image. The remainder of the image background is black. I’ve made an alpha channel to cut out the black part, and show only the part that is made by the greyscale, and applied it to a material on the relief object. It cuts out the black allright, but now cleanly. All around the edge of the object there are what look like icicles hanging down. I’ve managed to minimize them somewhat by going into Photoshop and contracting the alpha channel selection by up to 5 pixels, but I can’t completely eliminate them. Does anyone know how to get a clean edge around this landscape? I’m keeping it as a Relief object so that i can animate the segment number as i fly in on it from a distance, so that it will become more detailed as you go closer. Don’t know if that makes any difference or not.
    thanks,
    Jack
    Brian Jones replied 20 years, 9 months ago 2 Members · 1 Reply
  • Brian Jones
    November 23, 2005 at 3:06 am
    Can’t tell without seeing the image. Alpha shouldn’t change with changing segment number (well other than the shape change due to fewer segments).
