Activity Forums Adobe Photoshop Alpha channel export to FCP
  • Alpha channel export to FCP
    Posted by Espnetboy3 on October 11, 2005 at 2:01 am
    I have been having trouble bringing in single frames into FCP from photoshop. I was told if you use a transparent background and draw on top of that and export you will have ur alpha channel. When I bring it to fcp the backdrop is white and I have to sit there and key it out. Any suggestions? With after effects I make a title and render out animation with rgb+ alpha and it works great.
    Richard Harrington replied 20 years, 11 months ago 3 Members · 3 Replies
  • Richard Harrington
    October 11, 2005 at 12:42 pm
    Try the search posts option and you’ll find an answer.. or even just look half a page down at the subject Alpha?
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Jim Kanter
    October 11, 2005 at 2:14 pm
    When creating a Photoshop file make sure the content is set to transparent. Also make sure that the layer is not named BACKGROUND.
    FCP will recognize PSD opacity automatically.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
    October 11, 2005 at 5:43 pm
    But not layer styles, or blending modes, or if you change the stacking order of layers, or add layers etc.
    Stay away from layered PSD import into FCP unless its an absolute must.
