Activity Forums Adobe Premiere Pro Alpha Channel Export From AE
  • Alpha Channel Export From AE
    Posted by Marcelo Lewin on May 11, 2005 at 9:05 pm
    I can’t get the Alpha channel to show up in Premiere Pro (actually, I don’t know how to). I have a comp I rendered as a TGA sequence (RGB+Alpha / Pre-matted). The background is black. There are 2 layers. Both are text layers. One is white text the other is black text (like a shadow). I then animate the layers via text presets. After I render it, I import it into Premiere Pro 1.5. How do I make it to be transparent. I see the black background.
    Marcelo Lewin
    marcelo@thedailyfarce.com
    https://www.thedailyfarce.com/
    Marcelo Lewin replied 21 years, 4 months ago 3 Members · 4 Replies
  • Mike Velte
    May 11, 2005 at 10:16 pm
    Marcella wrote; “The background is black.”
    If the background in AE is actually a black layer, then alpha or not, you are exporting a black background, not alpha channel. Delete the black layer and re-export.
    Marcella wrote; I see the black background.
    If the background in AE just looks black and is in fact nothing, then Pro will recognize the alpha channel, but you will need a colored background on V1 in pro to see the alpha effect.
  • Marcelo Lewin
    May 11, 2005 at 10:47 pm
    I only have 2 layers in the AE comp (two text layers). I have the background color of the comp as black. Is there a way to make it “transperant” background. I’m not sure how.
    Thanks for your help!
    Marcelo Lewin
  • Steven L. gotz
    May 12, 2005 at 4:37 am
    You have to put it on track two in Premiere Pro, and put something on track one under it. Are you doing that? Because if you have it set for Millions of Colors+ then the alpha channel should be there.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Marcelo Lewin
    May 12, 2005 at 5:43 am
    Yeah. I have it as that. I have a feeling it has to do with the background in AE. I think I’m not saving it as a transparent background. Not sure how to do that. I’ll research more.
    Thanks.
    Marcelo Lewin
