Activity Forums Maxon Cinema 4D alpha channel changed when import into ae
  • alpha channel changed when import into ae
    Posted by Sandy Rahadian on October 29, 2016 at 4:34 am
    hello there,
    i made this scene using volumetric lights
    and when i imported into ae, it looks like this
    the opacity of the volumetric lights reduced alot, how do i fix this?
    i tried render without alpha channel, the result is very similar to the c4d viewport render.
    i always have similar problem when rendering volumetric light and alpha channel. but this one is critical.
    can anyone help me?
    Sandy Rahadian replied 9 years, 10 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 29, 2016 at 3:41 pm
    I can’t recreate the problem here. Are you using the standard renderer or the physical renderer? Are you exporting an atmosphere pass (which contains the visible light)?
  • Sandy Rahadian
    October 30, 2016 at 12:02 am
    actually i was exporting png sequence with no multipass, standard render. thaks to you i tried rendering multipass with atmosphere and it worked like charm. but anyway.. i had this similar problems before when trying rendering visible lights with alpha. should i always render with multipass? can i do it without multipass instead? just png sequence with alpa, but with correct visible light render included?
