Activity › Forums › Adobe After Effects › alpha channel batching
Posted by Alan Stephens on February 1, 2015 at 1:55 pmIs there a way to batch Animation files with an alpha channel?
I have a to of lower third seminar points to produce.
Does media encoder have a way to support alpha channels.
I can batch my full page with backgrounds no problem, but I don’t see a codec that supports alpha channels.Alan Stephens
Mac Book Pro 2.6, quad i7, 8 GB Ram, NVIDIA GeForce GT 650M 1024 MB, OS X Mavericks 10.9.2
Thunderbolt Promise raid driveDaniel Waldron replied 11 years, 7 months ago 2 Members · 7 Replies -
Daniel Waldron
February 1, 2015 at 8:56 pm -
Alan Stephens
February 1, 2015 at 10:05 pmI have been using the method you sent in the screen capture, only exporting one at a time.
Each time I have to reset the RGB + Alpha. Sometimes I forget. I’ve had over a hundred of these to do.
How do I save it as a preset? I don’t see any options here.
Can this preset be used in Media encoder with the Alpha channel?Thanks
Alan Stephens
Thunderbolt Promise raid drive -
Daniel Waldron
February 2, 2015 at 12:40 amClick the small arrow next to where you select the format in the Render Queue and go to the bottom where it says “Make template”. You can name it whatever you like. This preset will be saved and will also be available in Media Encoder.
Alan Stephens
February 2, 2015 at 2:22 amOk I made a new template and I can access in AE, but it doesn’t show up in media encoder.
I saved all to my documents, then tried to import in media encoder, but it was greyed out.
How do I make it available to media encoder?Thanks
Alan Stephens
Daniel Waldron
February 2, 2015 at 2:30 pmI just tried it and it seems the presets only appear in AME when you make them in Premiere. No matter, you can make a preset right from within AME. Click the + button that is in the Preset browser, then set it to Quicktime Animation. To add an Alpha channel, set the Depth option to 32 bit. That should do the trick.
Alan Stephens
February 2, 2015 at 3:32 pmThis is fantastic! It works great and will save me so much time.
Thanks so much!
Alan Stephens
