Activity › Forums › Boris FX Particle Illusion › Alpha Channel
Alpha Channel
Posted by Adrian anthony Vasquez salteiro on January 4, 2006 at 3:48 amI know you could make great things with images or videos rendered in alpha channel, but I don
Evideom replied 20 years, 8 months ago 3 Members · 2 Replies -
Aharon Rabinowitz
January 4, 2006 at 7:10 pmCan you please explain what exactly you are trying to do – even if it’s just an example – so it’s a little more clear.
Thanks.
Aharon
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Evideom
January 15, 2006 at 9:41 pmI am trying to mask/block emitters in Vegas 6.0 but for some reason as soon as I try to use the mask featue the emitter disappears. I tried to render in alpha but the option is not available, is that because I have the trial version of PI? If so, if I decide to buy PI will rendering in alpha solve the problem of the disappearing emmiter when trying to mask in Vegas?
