Activity Forums Adobe After Effects Alpha Channel
  • Alpha Channel
    Posted by Marcin Wojtas on July 25, 2008 at 7:44 pm
    I wonder is it possible to save a video in aftereffects with an alpha channel, then import this video in premiere and achieve a transparency of this video… I hve never been using the alpha channel, maybe this is very simple thing but I cant work it out…
    Thanks in advance!
    Marcin Wojtas replied 18 years, 2 months ago 2 Members · 2 Replies
  • Simon Bonner
    July 25, 2008 at 9:52 pm
    Yes, you can do this. Add your comp to the render queue and then modify the output module settings. In the dialogue box, set the channels dropdown menu to RGB + alpha. For some codecs this option is unavailable: try rendering a lossless avi or a QT animation. Anyway, seeing as you plan to work further in Premiere, it makes sense to use a lossless codec.
    It may also be worth watching Aharon’s tutorial on straight vs. premultiplied rendering here. Another of Aharon’s tutorials add to the concept here.
    Simon Bonner
    youtube.com/simonsaysFX
  • Marcin Wojtas
    July 26, 2008 at 6:01 am
    Thanks for your respond. I have already worked it out a bit another way. Everyting I did Was just render with ‘Loseless with Alpha’ output module and that’s working well enought for me for now. But I will surele watch these tutorials.
